LiKuiD
bahhhhhhhhh
- September 15, 2001
- Hillsborough, NJ
- '94 EB
When I installed my MC, I ran each ground (3 if I remember correctly) to its own body ground on the truck just to make sure it would all be ok. I'm not really sure what could be causing it to act differnetly between 0-40mph and above....possibly a VSS issue?
As for the MC adjusting, the only part that is going to adjust over time is the miles till empty meter. Everything else (except MPG, obviously) should be exact from the moment you turn on your car. After driving around for a couple months, my miles till empty reading is from what I can tell, almost 99% accurate. I've never driven below 20 miles till empty because I dont like going that low, but even at that point, the readings were correct. Also, fuel readings are always right on the money so if those are acting up on yours too, somethings screwy. Hmm....
