talked to glacier a little bit today... still have some questions for the rest of you though.....
http://www.transmissionpartsusa.com...5E_transmission_solenoids_p/609-00056841u.htm OR
http://www.transmissionpartsusa.com/4R44E_4R55E_5R55E_shift_solenoid_1995_on_p/230-00023393b.htm -- is this the shift soleniod i need for my 96 to fix code p0761
i need to get an epc, there are 2 epcs lisited on that site, and i am not currently aware which tranny i have, one is for a green screen and the otehr is red?
also, it was advised that i get the bracket for the epc as well, i have been told this is a ford only part. anyone have the ford part # for it? or a little beter description as to what it is?
i plan on doing the solenoid asap, then glacier told me to do the epc after i do a few fluid changes --- i will most likely put that in at the same time i have him do my valvebody (which will be hopefully soon)
i am going to run mercon 5 in the tcase and the tranny.... want to buy it in bulk... will need at least a couple gallons, then later on i will have the tranny powerflushed
