Ok, since I went off road without limiting straps I once again dinged the front pinion seal. While replacing, it appeared to be in backwards. When I last replaced it it went in like it had come out, but after closer attention it appeared to me to be backward so I installed the new one reverse of what was in there.
I assume(d) the spring should wrap the yoke seal area--it was inboard (inside the diff housing) on the seal I removed.
I installed the new one to look like this from the rear of housing
the one I removed was facing this way to rear
Ummm, which is correct?
