The brake components and shoes came to about 200 CDN, Haven`t gotten to bearings yet. And still need brake line.
ld50 said:Hey, still iffy on the antiwrap bar, samsoffroad .com shows this bar installed and it`s nowhere near the forward spring mount. Is it still just me or does it seem like it would bind? Can`t get my head around it man..
-gotta click the link, then click the pic of the bar on upper left, THEN find the mounted link there.
http://www.sams4x4store.com/index.html
ld50 said:Right now the y-pipe bolts to the exaust header are soaking in penetrating fluid. I`m not even gunna put a wrench on them yet for fear of ruining the bolts. Unfortunately they screw right into the exhaust manifold. I want to get them out of the way for re-install of the tranny, it`s a pain to work around them.
-But-
There`s another reason they have to come off; a darker more sinister reason. What I thought was only an oil leak from my oilpan actually may be all coming from another place, yes, my driver`s side head gasket is leaking, so I am (very) unfortunately faced with the job of replacing my head gaskets before the Explorer will see action.It will have to be the last step, I got too many bolts and gizmos scattered about the shop to worry about it for now.
thats not the head gasket, its the lower intake manifold gasket, and it took me 3 tries to get it to seal. there is no gasket there, its made out of rtv. thats why its so hard to get to seal and leaks easily.
ld50 said:Wow man, that would be a little easier than the head gasket, to say the least! I wouldn`t have thought that there is a way for oil to leak out through the intake manifold, you`re sure that`s it huh? THANKS for the post!
-PS I take it your oil leak ran down and dripped off the bottom of the tranny where it bolts up, and coated the inside of the bell too?
