BislamJoe
- November 25, 2000
- Texarkana Texas
- 1993 Explorer 4x4 XLT
Your list sounds pretty complete. I've been told that the D44 has the same u-joint as the D35 (a 297?) so that wouldn't be an issue, but with the D44HD or D50 it may... but those are probably big enough that I'd lose a lot of clearance. I'd be installing it myself for the most part, so that'd be a good bit less for me. I'd spend that money on either paint/fiberglass/tires or tools and parts. As far as the gears go, I've got a good buddy who can do gears, so it'll just be parts on that. I think I'm leaning towards 4.10 gears... though I like my gas mileage, so 3.73 may still be my final ratio. Another option on the gears would be to leave your front driveshaft off until you could afford the gears? I might do that if it looks to costly to do the gears right away. Also, you said "a little more" than the Perry's work, how big a difference? The D44 may not be a good option for you, since you're staying with the V6, but I'm swapping in a V8 (and a fairly stout one at that) so I might need the extra strength of the bigger differential.
Another thought struck me: I'm not terribly fond of lots of body roll. Now, with the coilovers, could I leave the swaybars off and still not have an undue amount of sway? Or do I need to add another shock up front if I want to run with no swaybars? I'd probably mount the coilover to the I-beam and the other shock to the radius arm. Or should I just give up on having it all and get some quick disconnects?
