Just replaced the left UCA and LBJ on my 98 xlt. Whoa -- sweated for 1 and a half days. I thank the forum for all the great info, while cursing you for all the confidence you gave me.
I'm the original owner, the front end hadn't been touched and boy was it rusted. Salt in the winters and ocean air in the summers. Yes, for me it was a day and a half and only got one side done.
Some folks might want to know that I was able to to replace the LBJ without having to separate the hub/knuckle from the axle. Had to stress, by this I mean a sharp outward pull, the whole assembly two times; once to get the lower section of the knuckle clear of the old LBJ stem and again to get it over the newly installed LBJ. It's possible to replace the LBJ without removing either the rotor or the steering knuckle. PITA but is was possible.
AutoZone press was used. Also PITA. Ended up beating out the old LBJ with a mini-sledge. When I do the passenger side tomorrow I am going to support the outside edge of the LCA because it makes no sense to me to hammer on something that is flexing; I bet then I'll need fewer controlled blows.
MountaineerGreen -- I sure do appreciate the pics. I tried the jack to press in the new joint but the vehicle kept lifting, despite my tapping around with a ballpeen.
To install the new LBJ I used a combination of pressing with the rented tool plus a steel plate I added to the top of the largest receiving ring, and hammering. Not much fun at all.
Right side will be tackled tomorrow. For that I have picked up a 2" black pipe cap from Home Depot and will be trying that as the receiver for the press.
My goal for the right side is to complete in a few hours and get the alignment done before I go to bed tomorrow night.
