masospaghetti
- October 22, 2006
- Huntington Beach, CA
- 98 XLT, OHV, 4D, 4x4, 5M
Comparing a M5R1 from a 2.9 Ranger and a 4.0 Explorer shows different "shifter stub lengths" (4-5/8" compared to 5"). I was under the impression these two transmissions were interchangeable. I know for sure the gearset is interchangeable and gives a steeper 1st, 2nd, and 3rd gear. I know also that the bellhousing pattern is the same.
What is the "shifter stub length"? Would the 2.9 Ranger transmission bolt-in to my 4.0 Explorer? Would I need to swap any parts to make the shifter work?
Here are the listings on Rockauto that I am referring to:
1998 Explorer w/ 4.0
ZUMBROTA RMTM5R1F8TN {Click Info Button for Alternate/OEM Part Numbers} Remanufactured Info
4WD; AWD; Manual trans.; All Aluminum, Shift Lever Bolts Into The Top Cover, 5 Inch Long Shifter Stub, One Switch Top Cover, No Speedo Gear Or Vehicle Speed Sensor, With Transfer Case Shifter Mounting Boss; Tag: F07A-CA, F17A-RA, F17A-RB, F17A-RC, F27A-ZA, F57A-FA, F87A-FA; Toyo Kogyo (Mazda) trans.
1992 Ranger w/ 2.9
ZUMBROTA RMTM5R1F4SN {Click Info Button for Alternate/OEM Part Numbers} Remanufactured Info
5 speed Standard Trans.; 4WD; Custom; STX Model; Sport; XLT Model; M5R1; All Aluminum, Shift Lever Bolts Into The Top Cover, No Bottom Cover, 4-5/8 Inch Long Shifter Stub, Two Switch Top Cover, No Speedo Gear Or Vehicle Speed Sensor, With Transfer Case Shifter Mounting Boss On Tail Housing, Tag: 93GTR-AA, 93GTR-AB, E97A-PA, F57A-FA, F70F-NA
1992 Ranger w/ 2.9
