- February 8, 1999
- Wayoutin, Aridzona
- '93 XL '20 ST
- Callsign
- AB7FH
I was planning on taking the Mach 1 to SEMA earlier this month. A couple days before I took the car out for a shake down as it's not driven often. Just wanted to make sure everything seemed right. I drove 20 miles into Wickenburg for lunch. Just as I got there I started to hear a metal to metal scraping sound. Opened the hood, and listened, but it didn't seem like it was coming from any of the pulleys. I thought it might have been a throwout bearing, but the sound didn't change when I moved the clutch pedal. I drove it home figuring I would look into it more when I got it back. On the way home I started smelling buring clutch. Made me think it was the transmission's clutch again.
I didn't have time to look at at when I got back so I checked it out the first thing the next day. I pressed on the serpantine belt to check tension, and the belt was broken. Fully in place and laying across the pulleys. It must have failed as I was pulling in because I didn't lose powersteering or hydroboost brakes on my ride. Most importantly the engine didn't overheat!
WIth the belt out of the picture I started spinning pulleys. The A/C pulley was locked up tight. Seized. Check out the damage! I am so lucky this didn't happen in the middle of the desert somewhere between Las Vegas and Home. That could have been an expensive tow.
