NotTrent
- February 11, 2024
- Breinigsville, PA
- 2008 Explorer XLT
I am pulling out what little hair I have left out. I have a 2008 Explorer with manual AC. I had a stripped gear in my blend door actuator so I removed the actuator and replaced the gear. Before I bolted it back in I plugged the actuator in to make sure it was good to go but when I turn the key on, the D shaped rod rotates once (like it goes from a/c to heat) and then after that it does not move when I adjust the temp. I have read about the reset for the EATC but is there one for manual?
If I unplug it and plug it back in it does the same thing, it just rotates from one side to the other once then doesn't respond to temp change.
