that sucker may or may not fit, but you are going to have to run 90 degree fittings right into it, with the canton I have 1/4" MAX clearance between oil filter mount and steering box
1/4" is NOT ALOT
running brass fittings into that adapter, deep enough so they make the 90 degree bend and clear the steering box is just asking for trouble, you will be stuck with the fittings pointing in the direction they end up opinting at when the adapter is finally tight to the block, for all you know that could be 90 degrees from where you want them coming out, the two 90 degree elbows willbe hitting each other if you can even get them pointed in the right rdirection, one may shoot straight up the other to towards the firewall, do you see what I am saying?
Now you have hoses attached to fittings plumbed into the adapter down behind your steering box that you cannot service, the hose clamps, etc will be BURIED, you have to pull the engine up ALOT to get in there, and it would still be a huge PITA with the steering box, ac compressor, fuel lines, ac lines etc all trying to occupy that space
Have to raise the engine 4-6" just to attempt to service it, you do NOT want to skimp here
ON top of all that "pot" metal oil filter adapters LEAK, thats all there is to it.
Get the Canton billet 360 degree adapter, you can still use a cheapo remote filter mount, but put the Canton mount on the side of your block, it is billet, it turns the hoses 90 degrees for you, it will not leak, and you can turn it any way you want to run your hoses.
I think I paid $60 for the Canton? Worth every penny for peace of mind!!
I have a "be cool" cheapo oil filter mount for my FL-1a filter, I also ran my mechanical oil pressure gage to the be cool filter mount, I plugged the other open hole..... (4 way adapter)
I am running a Carter $35 OEM fuel pump in my tank, works just fine for me! plenty of fuel rail pressure even at WOT
