Minimal lift for 34x10.50x15? | Ford Explorer Forums
Freshmeat
Denham Springs, LA
1994 Ranger STX SC
What's the least lift I can run to clear 34x10.50s on 15x8 wheels with 4" BS?
I have a 2" lift to go on. Can I get away with that and cutting? What if I add 2" wheel spacers? Would that help or drive it more into the fenders?
It's not a pretty X by any means- I bought a sawzall for the sole purpose of cutting my project 4x4s...
Any help would be appreciated.
not worried about it.................
2" suspension + 3" body lift, let the sawzall take care of the rest :dunno:
thought the 33x10.50 was a "pizza cutter"...................
I have never heard of 34X10.5 who makes those?
Interco makes them in an LTB. I try to support local companies whenever possible. I know second hand isn't necessarily supporting them, but it's still representing a great brand. Let me see if I can link to it...
http://www.intercotire.com/tires.php?id=7&g=1
The tires have about 3,000 miles on them. He offered them to me for $350, mounted and balanced on 5x4.5 steelies. I can't pass up the deal. Was planning to run 31s for a while, but I'll go bigger now and regear ASAP.
I had a 5.5 superlift on Haze and ran the 34's with no rubbing.
Plus I only snapped 1 front shaft in 2.5 years of wheeling it that way.
A 2" suspension lift and a 3" body lift can usually cram 33 x 10.5's, so you can probably clear 34x10.5's with the sawzall.
I'd go with the 5.5 lift, though. You gain a ton of travel with the increased height, plus more ground clearance with the SOA in the rear.
If you're going to re-gear and disassemble the TTB anyway, not too much work throwing a lift on there while you're at it.
They're perfect on stock 15x7 wheels.
I'll do the 2" suspension lift and keep an eye out for a used body lift, but I'm not going to spend $200 on a body lift when I could apply that toward a 4" suspension lift... plus, I wouldn't go over 2" on a body lift because they just look awkward with the frame hanging down so low.
...but anything getting in the way beyond that... will meet either my sawzall or my BFH. :D
I was contemplating running 34's on my old 92 with 2" of lift. The plan was to have Alcan spring make me a custom set of rear springs with the center pin moved back 1 1/2" (to help with clearance between the front of the tire and the rear door) and put on a set of 3" bulge fiberglass fenders (can't rember who makes them). Everything should have cleared with a set of 15x7" wheels w/ 3.75" backspace and some triming.
The 2" lift is intended to be temporary until I go 4". I'll see how things fit for a while and clearance will determine whether I go up or regear first. I'll most likely grab a Gen2 8.8 to regear and go with a ******* pack SOA when that goes in so I can get gears, flex, and discs all at once.
Picking up a replacement A4LD tomorrow morning. Going to put in a shift kit before it goes in.
