- June 17, 2004
- Knoxville, TN
- 98 Limited AWD 302
That brings up the 4WD operating system as I was deciding how to do it years back. I wanted the A4WD but I knew the internal clutch might be a issue with unknown power levels. In my research I found out that the 98 Expedition uses a GEM and different 4WD switch that provides locked 4WD(mechanical), and not use the TOD/clutch parts. Those control the shift motor to obtain 4WD Hi. I have a 98 Expedition GEM, and the 4-position switch(2WD,A4WD,4WD H, 4WD L), but making use of those isn't easy, maybe not possible. But I got them thinking maybe I could figure out how to utilize the GEM 4WD circuit.it is exactly the same and thats probably what killed mine and why after being the only V8 two door with a 4406 e shift i swapped in a manual 4406
If the Explorer A4WD system was reliable, I'd rather go that simple route. Dissecting the Expedition GEM and making that work might be way over my head. But I did find that the Expedition switch can mount to the Explorer bezel, it would be slick to have the 2WD position just to the left of A4WD, and not labeled.
