new engine!! NO START!! | Ford Explorer Forums
kdogg212001
stockton, california
94 xlt
ok i gotta 91 xlt 4.0 for $300.00, the engine has benn totally rebuilt, it has new rings, head gasket and powersteering pump and radiator as well as a ac computer($1500.00) ,it cranks over and will not start!! i thought it was the fuel pump but it was not that, the wires on the engines side of the fire wall have a signal but the wires inside the car dont!! anyone got any tips!!
300 bucks and fully rebuilt? Sounds too good to be true!
Good luck
no i dont wonoder why, i wonder whats wrong!!! ha ha well anyone got some help
Yeah... plug in the interior wiring. Check the connections at the underhood fuse box. Then make sure the ground from the engine to the firewall is attached. While you're at it check all the grounds.
Along with spark, do you have fuel pressure at the fuel rail?
You need to check: spark
check fuel pressure
then check for power at the injectors and engine sensors.
Its likely something simple..
thanks for the suggestions i will consider them all and let you know how things turn out
