96eb96
- October 20, 2004
- Albany, NY
- 96 EB V6 OHV 4WD
To Test ECT, KOEO in the morning. IAT should equal ECT within 5 degrees with scan tool. Watch it warm up and monitor the sensors. Come back an hour later, ECT temp should be 10-20 degrees less. Unless you just want to be a parts changer like every other tech. :lol:
Short drive cycles are brutal on a car, that is considered very severe service. There are places that clean injectors for under $100, and make sure there is a factory spray pattern. I would use top tier gas (Mobil) which has high detergents for a while. Crappy cheap gas can also cause this. Remember this is an old car, cheap gas from 10-20 years ago could have little detergent and cause this. Check your PCV valve too, it can create a dirty intake. Only buy a Ford one, it is quite cheap.
yea i will, need to upgrade to post pics i believe. i got borescope down in intake below fuel rail. all the black and brown gunk on sidewalls stops and disappears before the valve. i guess its backside of the valve but it looks clean as far as i can tell with my crappy chinese cell phone scope lol. was reading about injector heat soak with short drive cycles. trying to clean oem injectors. energizing in pulses with cleaner. one def was plugged. also read if one is plugged engine reads lean and trys to overcompensate with other working injectors?
