Nataliator
- February 8, 2010
- Philly, PA
- '97 Sport
Hi All,
New member to the forums but have been lurking for some time. I joined to search, and unfortunately came up empty.
I have a 97 Explorer Sport, v6 SOHC 4.0 - and am currently experiencing a problem with the drive-line.
I guess first of all, I have seen so many threads outlining the transfer case #s and trans #s to each model, but I am confused on what I have. I am pretty sure I have a 5 sp auto in it, if that helps? The VIN is 1FMDU24E4VUB52446 if anyone could help me decode.
So onto the problem - I purchased the truck for next to nothing recently at an "as-is" auction, knowing full well I would have to drop some coin to get it to tip-top shape. Well after purchase, I took it to my trusted mechanic for a PPI, and he said all it needed was a ball joint, no big deal i had him do this work for me. He also mentioned that this truck was missing the front drive shaft but it drove fine, so I ought to buy one if I wanted to take advantage of the 4wd.
Of course it wasn't that simple. I purchased a drive shaft and hardware and installed it, only to find that my truck seemed to "jump" every revolution.
I have read alot from other posts here and i am not sure if the truck is stuck in 4wd hi or there is a problem with the t-case, or maybe in the front diff. It almost feels/sounds like the gears in the front diff aren't lining up tooth to gap once per revolution, but tooth to tooth causing the "jump" and loud "pop" sound. This occurs in a straight section and seems to magnify when turning, either direction.
So I have since removed the front drive shaft and driven it as a 2wd in the meantime. It hasn't given me any strange sounds or motions since, unless I cut the wheel all the way to one side or the other, then i get the same popping, jumping action, but its VERY VERY faint, whereas with the drive shaft on its loud and noticeable. I have driven alot since my experiments, and its been dead reliable, just no 4wd.
Does this sound like a t-case issue, or an issue in the guts of the diff?worse? both? Sorry for the long-windedness. I am prepared to have my tech look at it and hopefully fix it again, but I am hoping I can narrow down what my problem is so i don't have a nightmare story like some member's i have read where they take their truck in for repairs and after the repairs the problem still exists.
IF anyone can offer any insight or needs anymore information let me know!
TIA,
Steve
TIA,
Steve
