15,000 MILE ANALYSIS
At 15,068 miles I went ahead and changed my oil. I now have new Mobil One and a Bosch premium oil filter in my Explorer.
Before taking this final analysis into account, remember that unless you run a taxi service with your Explorer or do a LOT of towing, I probably run mine harder than you do: 100 degree summer daily commutes, driving every day in rush hour stop-and-go traffic, interspersed with several offroad trips in 4wd low on hot and dusty trails.
At 15,068 miles my TBN is still equal to or above a new dino oil's ability to keep the engine cleaned of acid combustion/byproducts. Oxidation is still less than half used up; 41% of allowable. Nitration is two-thirds used up at 68%. Nitration and oxidation should be at a similar level so the nitration is identified as being elevated, even though still not used up. Gary has said earlier in the thread that it is probably because of how hard I drive my vehicle. As a result of the nitration/oxidation ratio the analsyis suggested I check my pollution control system.
New developments at this mileage: a notation of "silicon elevated due to to silicone lube or sealant"; and the viscosity finally inched up out of the allowable range for 30 weight oil (it's become between 30 and 40 weight oil now).
I still have the elevated levels of aluminum I always have had. I have a new theory that it may be a sign of wear and a possible future problem from the "notorious" timing chain tensioner in my SOHC.
The analysis finally suggested changing my oil now, which as I stated earlier I had already just done when I sent in the sample.
Since my onboard trip computer/message center has its oil change setting default at 7,500 miles, I think I will simply use that from now on. I would have no problem running the oil for 10,000 miles (with a 5k mi filter change mid-way) based on my analysis at that mileage, but for simplicity sake I believe I will buy premium oil filters with my synthetic oils and just leave them both in for 7,500 miles at a whack and change both then. Should I ever begin easier driving -- less stop-and-go, more highway miles -- I wouldn't hesitate to run it 15,000 miles again. Every reading I got was still way within acceptable range except my viscosity showed up slightly thicker than 30 weight. Big deal
I believe we have
conclusively proven you can put more than 3,000~4,000 miles -- a
lot more -- on your oil (at least we know you can if you are using synthetic), which is what the consensus opinions were once Travis started this thread.
CONCLUSION FROM RESULT OF THIS EXPERIMENT
Travis, you started this thread asking if you really can run your synthetic oil 15,000 miles. The answer is yes. Your question assumed 3,000 mile filter changes with single replacement quarts and I did it with 5,000 mile filter changes. If you are running synthetic oil, you are safe to 15,000 miles no matter how hard you drive. If you want to be very conservative you can still:
- change the oil at 10,000 miles with a filter change midway at 5,000 miles; or
- change every 7,500 miles.
We now have hard data to prove this. We no longer have to rely on conjecture and guesswork from previous habits and Jiffy Lube commercial suggestions.
I think we all owe AgExplorer a debt of gratitude for ponying up the analysis kits and enabling this study.
PS / I would still like to see someone belly up to the bar and run dino oil for 5,000 miles; or 6,000 miles with a filter change halfway through at 3,000 miles. I bet dino oil lasts at least twice as long as we think it does.
[Edited by GJarrett on 08-05-2000 at 09:01 AM]
