Pickle 2.0 - Full Width SAS/SOA 4406 swap | Page 9 | Ford Explorer Forums
you probably did... I've read so much I've confused myself.. again.. n I've had 8hrs sleep since thursday
Si
ok... so, I've been doing some emailing back n forth with this guy
http://www.bloodyknucklegarage.com/
He worked for Cage to make their extended arms, n when they went bust, he had all the rights/plans so set up his own shop.
I'll be using him for the arms, upper/lower coil buckets, shock mounts etc...
I'm going to be ordering my rear truss from Artec shortly and was also wondering where is the best place for SOA anti-wrap perches?
Si
I bought my SOA perches from RuffStuff.
They're pretty long unlike the factory perches.
Si,
At one point superlift was making these incredibly convenient SOA conversion brackets. No cutting or welding required. I they were like $50 for the pair. Easiest way to do it if you can find them. I'll see if I can get a part # from my archives.
Those are what I bought.
Everyone I know that has used them haven't had issues with axle wrap.
I can't remember but I think it was Flounder that had bolt on soa perches. Don't quote me on that though. lol
I ordered these yesterday, should be here in a week or so, so I can see how wide I'm gonna sit with the wheels/tires on...
I'm going to order my perches this week too, also, is there a place I can get those things that sit on top of the springs to keep the u-bolts in place? you see them on top of the leafs on newer F150s and such...
Si
So, Last night, I dropped of my FW D44 at the local mad scientists shop to have 6" removed... probably the one n only time I'll ask someone to take 6" off my shaft... badum tish...
And just to confirm that this is the correct shaft I need before I go and order it
linky
Si
Making progress. Sorry I can't help confirm if you have the right axle shaft..
linky
Si
Bkennedy just went through this. You might want to check his thread or ask him...
