doctordeeptrack
- May 20, 2015
- Dallas, TX
- 2001 Ford Ranger 4.0L V6
I installed new timing chains and tensioners from NAPA about 5 months ago. I used Cloyes. Did a complete engine removal on the stand to accomplish this. Had to do a job in Santa Monica and left it idle till just now. I finished the install. New gaskets thermostat etc and replaced all the wiring and hoses and fired it up. It ran smooth and quiet for about 15 seconds. I heard a sinister little click and it went right back to the nasty shaking and clattering that I had hoped to cure. I purchased the special OTC 6488 4.0 SOHC cam tool kit to do the install and took my time so I feel like the cams were properly installed especiall in light of the fact that it started immediately and smoothly. Someone help me here if my Ranger inexperience shows but the only way I can see to check the driver side tensioner is to remove the intake. I did so. Also removed driver side valve cover. The cassette looks good and the chain looks good. Upon removing the tesioner I noticed that no oil came out of it. Shouldn't it be full? I turned the motor over with the tensioner out to check the oil galley and it was clear and pumped out oil into the tensioner hole. I primed the tensioer with a squirt can and reassembled. Same clacking and rough running. Any ideas?
