dani9678
- December 24, 2003
- Jacksonville, FL
- 1995 Explorer 4wd 4.0
I came across the following parts site looking for a lower steering shaft for a 1995 Explorer 4WD. The following link will take you to the part diagram along with the part I am referring too. The price is $58 and I figured that was to good to be true. I later found that they were referring to the lower shaft minus the universal joint. Isn't the lower shaft and the joint made as one piece? Take a look at the link and tell me what you think. Number 6 is the part that I am looking at. I need the universal because the boot has gone bad and it now gets stiff unless I keep adding a spray lube to it.
Matt
http://www.parts.com//oemcatalog/in...=1995&catalogid=2&graphicID=MF95270&callout=6
Matt
