Lewis Littleton
- November 9, 2001
- Pickens, SC
- 2000 EB, 94 Navajo LX
Coincidentally, both the Ford and Pioneer model numbers were the same as yours. That is why I ordered the same part number as you did. I just got the parts kit in today and installed only the display power supply board (I also received the connector block for power, speakers etc. as well as a small circuit board that solders to the main board somewhere). Anyway, the only difference that I could see on the new board is that the larger (1 watt?) resistor leads were bent so that the resistors will stand higher above the circuit board for better cooling and to keep the heat off the board itself. It is working great now. Total cost including S & H was $96.90. Thanks again for the information.
