motox737
- March 6, 2014
- iowa
- 1999 ford ranger 3.0 4x4
I have a 99 ranger with 3.0 and 4x4. when I bought the truck it wouldn't drive in overdrive or in 1 manual. if I put the truck in 2 manual to take off then shift into od I could drive normally. until I slowed down or stopped. so after much reading of this awesome forum I decided to rebuild the valve body replace all solenoids and rebuild tranny with new seals orings clutches bands and servos. I put all back together with much diligence only to have the same issues. so I decided to do a pressure test which showed good pressure in all ranges at idle. now when I performed the stall test all rpms were too high except in 2 manual.so the only thing left is to rebuild the pump, correct? any thoughts would be greatly appreciated. thank you much
