Exproblems
- April 17, 2011
- Orchard Park, N.Y.
- '05 Explorer XLT 4.0L
You may have a "air recirculation door" problem. It is located above the blower motor, which is located behind your glove box. The air recirculation door unit is at the top, just under the bottom side of the dashboard. This door tends to fall off of it's hinge pins and drop down in the air box blocking air flow to some vents, affecting the AC and Max AC coldness. There are posts in here on how to fix this, just use the search box to find them. It is a big job to do, you have to partially remove the dashboard to get at it. You also could be low on refrigerant in the AC unit.
>>>>>>>>>>>>>now if i can just figure out why it isnt blowing "ice" cold ....
