96eb96
- October 20, 2004
- Albany, NY
- 96 EB V6 OHV 4WD
I did some searching but I want to make sure. My shakles are rusted to swiss cheese and I want to change them. One is worse than the other. The top bolts will come out easily, but the bottom spring bolt is rusted into to the inner bushing. Heat isn't an option because I'll ruin the rubber bushing and no one carries them (I tried everywhere locally). I don't appreciate the smell of burnt rubber either. Also, I don't want to put the truck out of service if I destroy the shackle and have a frozen bolt in the spring. I also bombed it with pb blaster.
One shackle looks like its going to turn to dust if its pounded, then I'll have a floating leaf spring and a siezed up bolt and bushing.
I tried pounding the other side with a breaker bar/socket sledge combo, but it merely pushes the inner bushing against the other side of the shackle.
My next thought is a C ball joint clamp, hopefully the tailpipe will clear and the shackle wont crumble. The rust under this poor truck makes me think about getting rid of it .
Any advice here? Thanks in advance
