Show us your custom bumpers!! | Page 22 | Ford Explorer - Ford Ranger Forums - Serious Explorations
Exploring XLT
Never Stop Explorering
Location
Stony Plain, Alberta, Canada
Stony Plain
93 Ford Explorer XLT 4WD
Two inch receiver for my winch, made out of 4" channel with 1/4" top plate and top edge, brush bar is 2" steel tubing.
mounty71
It's green, not gray.
Oakland, CA
'00 Mountaineer
Are you in the Bay Area? I recognize the 454 Motorsports sticker.
Fire
Location
Arizona
N/A
2002 Sport Trac 4x4
Old OEM plastic bumper cracked and rattled. Built this for better clearance on the trail. 2"x.120" tubing, 3/16" plate, receiver. Don't look close, --hadn't welded much since jr high, lol.
Jessejp05
Plant city Florida
1993 Ford Explorer XLT
Here’s my bumpers. Front is a weld it together kit from a XJ. Rear is custom built with .120 1.75 DOM tubing. Thinking of redoing the front bumper…
BKennedy
Elite Loser
Staff member
Moderator
Location
USA
San Diego, PRofK
1994 XLT
Front bumper looks good. Why did you make the loop so long for the tire carrier? Maybe planning on adding a gas can? It's too long in my opinion. The shorter the lengths, the stronger it will be. The tire is heavy and the wiggle while going down the road can cause it to fail. You gusseted the heck out of the mount, but not the tube.
Jessejp05
Plant city Florida
I left room for the tag mount, a drop table and jerry can mounts. Also, the tire is mounted closer to the swing so the weight is on that side and not in the center and when it’s latched there is a center support that the “weight” rest on.. not the latch or swing. It’s doesn’t wiggle much at all and doesn’t sag when open.
BKennedy
Elite Loser
Staff member
Moderator
Location
USA
San Diego, PRofK
1994 XLT
OK, cool. I would add a gusset at the other end, maybe join the down tube and the latch point so it doesn't want to crack there. I have never seen anyone use two rod ends for a tire carrier, I like that.
karlos2
98 Explorer
Allen Clark
Florida
2014 Ford Explorer
traveler
Staff member
Moderator
Location
Mesa AZ
Mesa
2000 EB Explorer 5.0
While I can't take credit for the design, or the cutting, or the welding... (Ok, I didn't make it myself, lol) I did paint it myself! :)
Gotta give credit to RockRanger for all the hard work and to Matt (Local Welder) for the assembly. Still I think it counts as a custom bumper.
I think its one of the very few bumpers on here that isn't painted black! :)
FROADER
Staff member
Moderator
Huntington Beach, CA
1991 Eddie
traveler
Staff member
Moderator
Location
Mesa AZ
Mesa
Only Downside is, with the body lift and the better clearance bumper, it sure exposes the Crossmember. I've got a skid plate on order to fix that issue however.
BKennedy
Elite Loser
Staff member
Moderator
Location
USA
San Diego, PRofK
1994 XLT
That cross member is stout, you would have to hit it with something hard to move at speed to do any real damage.
I really like that Rock Ranger designed bumper.
traveler
Staff member
Moderator
Location
Mesa AZ
Mesa
True, but there are some BIG, firmly planted rocks out here in AZ!
BKennedy
Elite Loser
Staff member
Moderator
Location
USA
San Diego, PRofK
1994 XLT
That reminds me of how long time member Diff Wack Daddy got his name. He was cruising along a wash near Truckhaven Hills, California, when he center punched a large rock, most of which was buried. It bent his driver side beam so bad it pulled the bolts out of the diff housing. He ran his winch line to my front bumper with a snatch block and back to the beam to pull it back sort of straight. Had to have another Explorer tie off onto my rear bumper to keep it in place. I think he went with a solid front axle shortly after.
traveler
Staff member
Moderator
Location
Mesa AZ
Mesa
LoL and THAT'S why I want the Skid Plate! 😆
