2000StreetRod
Moderator Emeritus
- May 26, 2009
- Greenville, SC
- 00 Sport FI, 03 Ltd V8
Remove right cassette
Remove right cassette (camshaft sprocket, guide assembly, chain and jackshaft sprocket). The photo below of my guide assembly at approximately 150,000 miles illustrates why the traction side needs to be reinforced with metal.
The tensioner (slack) side of the guide assembly is in good condition with less than one tenth of the depth of the chain contact surface worn away by the chain. The slack side could easily last for another 500,000 miles from a wear standpoint. The wear on the traction side of the guide assembly is comparable to the slack side and the depth of the remaining chain contact surface is about the same. The traction side cause of failure was structural possibly from physical stress, vibration, heat or a combination of all three. I suspect the reason the timing chains break is because a large piece of guide fragment gets wedged between the moving chain and some stationary item such as the block or head. If the plastic had been bonded to a metal backing in a manner similar to the way brake material is bonded to a brake shoe the guide would still be intact.
