wr250xguy
- December 26, 2022
- Graham, WA
- 2014 Explorer XLT V6
Good evening all. I have a 2014 N/A V6 explorer that I just completed a water pump/timing set on. After maybe 300 miles of driving I have 2 issues. I have a p0340 and p0344 and also have a terrible squeal when the engine is warm. It does not squeal on cold startup. I have replaced the belt tensioner and have also ran with out the belt for testing and the squeal is still there. I used a gates water pump. Other work performed was a cloyes timing set and dorman cam phasers. For the cam codes, I have replaced the sensor and also the connector plug on the harness. Also, i have double checked timing and everything is still lined up. Could these issues be interrelated or...... Attached is a short video on the noise in question.
