Supercharger install
Join the Elite Explorers for $20. Gets rid of the ads!
Explorer Forum has probably saved you that much already, and will continue to save you money as you learn how to diagnose fix problems yourself and learn which modifications work without having to experiment on your own. Elite Explorer members see practically no advertisements, no banner ads, no double underlined links, can add their own profile photo, upload photo attachments in all forums, and Media Gallery, create and save more private Conversations, and more. Join Today. Your support is greatly appreciated.
donalds
Location
Stem
Nc
1999 ford explorer sohc
Today I installed the 255lph fuel pump took a hour real nice pump heavy and quiet
Mr. Alligator
Tampa, Florida
1997 XLT Explorer
Lawnmower engine?!? .... well done, Donald’s!
donalds
Location
Stem
Nc
I noticed that the instructions said to pull bend the coil pack bracket back towards the brake booster 4.0 SOHC Supercharger Kit - 02-05 Sport Tracs/2dr Sports
Well the valve cover is aluminium and the coil pack bracket is built into it so I need a bracket
I obtained a bracket from a ranger and don't forget the hardware
donalds
Location
Stem
Nc
My son cut grinded and painted
Cut off the unused part of the bracket
donalds
Location
Stem
Nc
I realized I needed a throttle cable from a ranger
Because of the bracket that came with the install kit is not compatible
I hope my gas pedal will work still
donalds
Location
Stem
Nc
Also the throttle body on my year explorer is not compatible so I got a jy unit 2002 ford ranger
donalds
Location
Stem
Nc
I cut the original coil pack bracket so I can retain the main harness holder
CDW6212R
Hauls the mail.
Knoxville, TN
98 Limited AWD
It looks great, but I think that's too big for the lawn mower?
donalds
Location
Stem
Nc
Shhhhh
donalds
Location
Stem
Nc
Both brackets installed
Blown
2000 X-Edge
I wonder if you can see this? My old tune table for fuel.
Hey why not my old timing table?
Stock fuel 12.7 Even at 5lbs it would run better with more fuel and less timing. I ran this much timing with 8-10lbs boost and alcohol/water injection. It would be about right for 5-6lbs of boost. I like and use the Tweecer, works for me, what I started with, but there advantages and disadvantages to what's available to tune these.
donalds
Location
Stem
Nc
I am just learning about all this turning
I can read the tables but don't know what I'm looking at
However the kit does have ports for water alcohol injection but at 3.5 psi is it really necessary? Thank for the advice
donalds
Location
Stem
Nc
Today I tore down everything definitely need to reroute lots of wires wish me luck
CDW6212R
Hauls the mail.
Knoxville, TN
98 Limited AWD
Good luck. If you have to reroute the plug wires at all, keep the used wires until the project is done, and then install new plug wires. Old plug wires develop misfires easily when they get handled rough, so baby them or replace them.
Blown
2000 X-Edge
The stock tune will be fine at 3.5lbs, but I would bet you'll want more after you get it all set-up and working for a while..........
donalds
Location
Stem
Nc
I'm pooped
donalds
Location
Stem
Nc
Today I started the surgery
Went for a good ten hours with my son
Started with the Damn wires
This thing earned it's way today
All the blue tags are all the wires that were cut and extended and solder ed and shrunk tubing used
donalds
Location
Stem
Nc
. Sorry for the bad pic
donalds
Location
Stem
Nc
I installed the blower and upper and lower plenum
And the intake and it's lid
Also hooked up all the vac lines
O My partial Explorer Express supercharger kit install Modified 1995-2001 Explorers 17
J Supercharger install begins this weekend! Modified 1995-2001 Explorers 15
M Spring is here. Supercharger installation time is coming. Lets talk about cooling fans Modified 1995-2001 Explorers 20
9 Weiand supercharger kits for 5.0 explorer Modified 1995-2001 Explorers 6
M Supercharger has arrived for BIG WHITE!! Modified 1995-2001 Explorers 0
R Supercharger Crank Pulley Modified 1995-2001 Explorers 14
C just adding a supercharger Modified 1995-2001 Explorers 4
X saleen xp8 supercharger? Modified 1995-2001 Explorers 2
M Supercharger questions Modified 1995-2001 Explorers 3
zachow3 Supercharger anyone? Modified 1995-2001 Explorers 47
G Turbo or supercharger?? Modified 1995-2001 Explorers 6
J Supercharger or Stroker for Towing? Modified 1995-2001 Explorers 21
M Eaton M112 Supercharger Installed Modified 1995-2001 Explorers 38
D Thinking of throwing in a supercharger Modified 1995-2001 Explorers 1
T Supercharger or Turbocharger Modified 1995-2001 Explorers 1
C Supercharger 4.0l SOHC Modified 1995-2001 Explorers 1
C Powerdyne supercharger..??? Modified 1995-2001 Explorers 11
O are there any supercharger kits for a OHV 4.0 Modified 1995-2001 Explorers 7
V How much force to turn a supercharger? Modified 1995-2001 Explorers 8
7 5.0 supercharger ?'s Modified 1995-2001 Explorers 3
4 M90 supercharger swap onto 4.0 sohc Modified 1995-2001 Explorers 11
J 4.0L OHV supercharger? Modified 1995-2001 Explorers 3
4 Powerdyne supercharger help! Modified 1995-2001 Explorers 2
5 Whipple Supercharger Modified 1995-2001 Explorers 3
S Will a 3.8 supercharger work for a 4.0??? Modified 1995-2001 Explorers 2
P ford supercharger? Modified 1995-2001 Explorers 4
W Supercharger woes continue: sigh :( Modified 1995-2001 Explorers 9
W Supercharger bearings went today :( Modified 1995-2001 Explorers 9
W Supercharger troubleshooting: FMU/FP Modified 1995-2001 Explorers 3
C Supercharger Modified 1995-2001 Explorers 0
E Supercharger Question Modified 1995-2001 Explorers 3
2 turbo or supercharger? Modified 1995-2001 Explorers 25
W Supercharger Update Modified 1995-2001 Explorers 0
B How to install a amplifier in a 2nd gen Modified 1995-2001 Explorers 0
M Flash To Pass not correct after LED headlight install Modified 1995-2001 Explorers 0
K is possible install wheel hubs Ranger 98 in Explorer 98 to convert manual locking Hubs Modified 1995-2001 Explorers 6
Andrew Bagwell Rough Acceleration after header/exhaust install Modified 1995-2001 Explorers 5
3 Lowering via TT/blocks and TMH install - which one first? Modified 1995-2001 Explorers 1
3 Install/help me install my TMH's? Modified 1995-2001 Explorers 0
M OBX Header Install complete - only issue needing help on Modified 1995-2001 Explorers 25
96ex5.0 OBX header install Modified 1995-2001 Explorers 23
J One way to install a better seat in the explorer Modified 1995-2001 Explorers 0
B Suspension overhaul and torsen install Modified 1995-2001 Explorers 3
M A/C Evaporator Fan Install Modified 1995-2001 Explorers 2
A How to install mechanical oil pressure gauge in a 98 Merc Mountaineer 5.0? Modified 1995-2001 Explorers 3
R 5.0 Manual Trans Install Modified 1995-2001 Explorers 1
G EGR tube install write up with pictures Modified 1995-2001 Explorers 2
J what other years on i install my 99 engine Modified 1995-2001 Explorers 1
2 HID install for fog lights need new wiring help mod? Modified 1995-2001 Explorers 0
J How to install a second battery for electronics? Modified 1995-2001 Explorers 1
Similar threads
