- July 13, 2005
- Location
- NC
- Garner, NC
- 2019 F150
- Callsign
- N1LVN
Anyone out there taken off the front cover from a 5.0L lately? I started out replacing the radiator on my '97, and decided to take care of the leaking front seal while I was there. Then I decided that it was enough work, and I should go ahead and put in a new timing set and water pump, so I would never have to worry about getting in there again. Problem is, I have EVERYTHING removed, except the front cover, and the darn thing won't budge. The top, where the water pump mounts to, is loose, and the right side, down by the pan shows movement, but something on the left side is stick, and it just won't budge.
Hoping someone has some pointers. I've been down for 3 weeks now, since it's tough to get consecutive days to work on it. I just don't want to mess up that front cover 'cause that's $300, added to the almost $500 I'm putting in it already. I'm able to get a putty knife between the oil pan and the cover. It appears to be holding on to the left side, just above where the cover meets the oil pan, where it bolts to the block. I've hit the bolt holes with some PB to try loosening it up. Hasn't seemed to help any.
