Longs
- February 17, 1999
- Cranberry Township, PA
- '93 Limited
I'm thinking about doing the flush, and was wondering if anyone has used the method below. Will the transmission siphon new fluid in as decribed by "Greg J" on the maintenance tips page?
This is Greg J's Description:
My method does not require "pinch-clamps", calibrated bottles, or putting the oil in a quart at a time. There is also very little mess. In fact, I stole the idea from looking at the T-Tech machine at Jiffy-Lube.
So, here is what I do. I attach tranmission hoses to BOTH the "from transmission" and "to transmission" connections at the auxiliary cooler. I use about 10 feet each since I do this all by myself and can keep everything near the drivers door.
The difference is you use two 5-gallon buckets instead of milk bottles. In one, which is carefully cleaned and dried, I put 16 quarts of tranny fluid (Amsoil, naturally). The other is used to collect the old fluid.
Put both buckets near the driver's side door of the vehicle so you can watch them. Make sure you know which line is "in" and which is "out". If in doubt, tickle the engine with both hoses attached and the outflow line will shoot t-fluid.
Now put the "in" hose into the bucket with fresh fluid so the hose is near, but not touching, the bottom of the bucket and secure it to the handle with duct tape. Put the other hose into the empty bucket and tape it to the handle, too.
Now, start the engine. You will see the dirty fluid flowing into the empty bucket and the new fluid being sucked into the tranny. No pressure changes anywhere in the system!!! Run the engine until the new fluid just starts to pull air (about 2-2.5 minutes) and shut it down. Reattach the connections. Check the fluid level, check for leaks and you are done!!
