Okay I'm trying to figure out the issue of the wot going lean.
I don't have a datalog yet because I'm out of town, but basically when The truck hits wot the signal from the tps is telling the computer to go into a different fuel source. There are 3 fuel sources (tables I guess).. Source 0 is cold start, then there is a 5 and a 3.. 5 is what it needs to be in but when you go wot is changed to source 3 which causes it to go lean.
Does anyone know what perameter needs to be adjusted or what is going on with it?
Thanks.. I'll have a datalog up on monday
