- April 3, 2008
- Gloucester City, NJ
- 98 2Dr,2,000 & 04 4dr xlt
Turbo
So at Idle LTFT has learned to add 17% on bank 1.
the others are insignificant at Idle.
At 2000 rpm LTFT has learned to add 27% on bank 1.
Bank 2 STFT was adding 11% at 2000rpm's but for now who cares because the DTC you had was for Bank 1.
With a misfire you will have more oxygen in the exhaust and as the rpm increases there will be even more.
That's why it probably went from 17to 27% at higher rpms.
In this case it looks like the misfire is effecting the air fuel mixture, not the a/f mixture causing the misfire.
If we did not have the misfire code we might think other wise. We will see.
