Centaurus5.0
- April 15, 2016
- 96'
It sounds like the injector slopes are wrong and I would be checking injector timing.
Ah!
If the CPS was a degree or two off..
That should do okay, I think about 60-62psi is a minimum level, before the PCM throws a lean code. The 55psi off is okay too, there are few vehicles that really don't leak down at all.FYI, finally got a fuel pressure tester. 64 psi when running, around 55 with engine off.
to be cautious, pull the oil dipstick and make sure it doesnt smell like gas. if it does, dont drive it, or start it. change the oil right away, and also have a look at the plugs. if they also look fouled, you might want to change them as well. hotroding is fun, but expensive.
What's the good word Josh?
I'm done going in circles with a place that won't listen to what I need them to do. I'm paying, shouldn't be a problem right?
