I've heard amazing things about them. What is the product called exactly? I'm looking to order but see a few different names. Does it go on like regular wax?
Goes on very easy! Also, it does not turn black trim white.
OK... depends on what you want to do. Are you going to "clay bar" your car and wash it by hand? If so then I would recommend buying the "show car kit" for $84.70 which has everything in it.
Otherwise, I would buy:
- ZFX Flash Cure Accelerator
- Z-2 Pro
- Z-5 Pro Show Car Polish
- Z-6 Ultra Clean Gloss Enhancer Spray
That list will run you about $63
I also recommend the Z-8 Grand Finale Spray Seal. The Z-8 is pricy at $20 a bottle so I use the Z-6 between washes to shine up the car and I use the Z-8 when I really want deep shine, like if I'm going out or picking someone up and I want the car to look it's absolute best.
The ZFX comes with four empty plastic bottles. You pour wax into one of the bottles and add a couple of drops of the ZFX to the wax. Shake it up and your ready to go. The ZFX allows for multiple coats of wax to be applied one after the other.
Without the ZFX, the cure time between coats is supposed to be hours.
I did not clay bar my new Explorer (although I did order the show car kit because I too was confused starting out).
The Z-2 is great for new cars and the Z-5 is great for cars that show swirl marks.
If a car shows swirl marks, you would polish with Z-5 for the first application and the follow up with the Z-2 which will provide a deeper, wet look.
Honestly, this stuff was so amazing and addictive, I ordered more after seeing the results.
I also was relived not to worry no more about the many different waxes/polishes that are at the auto parts store and which one I should use. I am a Zanio customer for life, that simple.
Oh yea, also remember to first wash your car by hand with "Dawn" dish soap to strip off any waxes before starting with Zanio. Washing with Dawn is a one time thing. After you was your car with Dawn and apply Zanio, you will not wash your car with Dawn again unless you are looking to start over.
Hope your results are the same if you try Zanio.
(They should send me free products for this unpaid advertisement!)
