- June 17, 2004
- Knoxville, TN
- 98 Limited AWD 302
Not with that transmission. Needs a 60* bell housing, which is what my 700R4 has, so it needs to be a GM based engine. The only adaptors for that transmission are for the OEM 4.0.
My thought was to use the 3.7 and 6R80 trans from a 2017 or newer F150. The sideways 3.7's and other V6's have internal water pumps, I have no thoughts to ever own one of those. I wonder if "they" would let you use the F150 or Transit engine in the Explorer, with you telling them it's from a late Explorer. They can take the same external parts, I'd figure they would go by your documentation for buying the donor engine.
The ecoboost engines all have the turbos mounted low and to the side, most likely those would interfere at the frame and/or UCA's. I'd try the NA 3.7 first, for that the upper intake may be too close to the AC box. If it would go in, shifted forward as much as possible, fabbing the engine and trans mounts might be the hardest parts to do, plus wiring.
