What ya think, 8" idea? | Ford Explorer - Ford Ranger Forums - Serious Explorations
00whxploder
Fitzgerald, GA.
2000 xls 4x4 now
So I've been doing some research and this is what I can up with.
I have 2000 Ex 2x4 and theres not much big lift options.
So for the front:
2" torsion twist
Doetsh 3" lift spindles Part#589830-2 $367.71
http://www.doetsch-shocks.com/9.asp
For the back
1" lift shackles Auto zone $20.00
Superlift 4" Leaf springs Part#01-194 $255.32
http://superlift.com/Catalog.asp?P=K494
and then the all around
Performance accessory 3" body lift part # pa-883 $189.00
http://www.performancelifts.com/cgi-bin/cart/PER883.html
If you're 2wd, that will work just fine.
Instead of the 1" shackle and 4" leaf springs, you could do an spring over axle (SOA) to get 5.5 to start with. If you're 2wd, you could also do a 2.5 torsion twist to match the extra 0.5" in the rear.
Got a good post on the conversion.
Yea that is what i was asking for thnx.
Not sure which link you're talking about, but I guess you're welcome.
