- June 17, 2004
- Knoxville, TN
- 98 Limited AWD 302
It sounds good, but have you done the real budget work? We want to help of course, but I don't want to push you into spending more than you planned. That's why I have mentioned costs for additional parts, several times.
For a stroker, you can shop around looking for used parts or for reciprocating assemblies, or short blocks. The 347 and 331 share the pistons often times, with the upper ring lands spaced for good oil control. The oiling and cylinder issues are almost the same now, which is why I jumped to the 347 instead of the 331. The good thing is that almost any builder is capable of preparing a block for the long crank, given adapters which make the grinding easy. Those can be had yourself for about $45 I recall reading.
Find your builder and consult with them about the balancing, the weight of the crank versus the dampner/balancer. They have to match, or the crank be possible to balance to match.
