ember1205
- October 5, 2014
- Northern Central CT
- 2011 Ford Explorer
I'm looking for people that have added the OEM hitch, not an aftermarket one, to an Explorer equipped with a rear camera / backup sensors. I need a hitch, but do not need everything that the actual tow package adds to the vehicle. I can manage quite fine with just the factory hitch (or a direct, identical replacement) and a 4-wire harness.
Please note: If you've installed an aftermarket hitch that sits BELOW the rear bumper, this is NOT what I'm searching for. I intend to install either the actual factory hitch or one that is identical, change the plastics on the bumper, and achieve the exact same look and feel that the factory tow package gives you by "hiding" the hitch behind the lower bumper panel when it isn't in use.
Please cite any details that you have pertaining to what you had to buy (part numbers, where you ordered, approximate costs, etc.) and what the installation effort entailed.
I know that the lower panel on the non-tow vehicles is a single piece of plastic that can be removed and replaced with a double-piece (one of which is the flat panel that snaps on and off to expose or hide the hitch). At least, I -think- I know this.
I have also read that the wiring harness is shared between the backup sensors and the trailer wiring, so it would seem that the plug can be added easily. Can someone confirm this?
Thanks in advance.
Thanks in advance.
