WHY Melted DPFE Sensor? | Ford Explorer Forums
michaelspayth
Bulls Gap, tn
2001 Explorer sport
I have an 01 Explorer sport....
Hate that I even have to ask something like this but.. what is this? How could this have happened? And how serious is it? Thanks in advance
easy to replace, but what caused the melt down ?
Short circuit if some sort!
First time I have ever seen this
You will likely need a new wiring pigtail and new dpfe (differential pressure feedback exhaust gas recirculation)
Check fuses
Clear codes
Install new dpfe and monitor it closely
Thanks for the help! Not sure what caused the meltdown or how long it's been like that. I'm under the hood often and would like to think that I would have noticed that if it had been that way for a while. Going to order the replacement part today
I've seen them melted before, egr gas, plastic part. It happens. Inexpensive replacements are sketchy.
Could be a restriction in exhaust, clogged cat. Hope not.
Disconnect battery while you swap it out. That will clear the codes, showing only new ones if any during a drive cycle.
From what I see, the heat came from the exhaust. I would think it could be high exhaust temperature which could be a number of things like exhaust valves not sealing or incomplete combustion and combustion in the exhaust. I guess it could be excessive back pressure as well but there should not be any gas flow but heat would flow. My bet is if you hook it up with a new one you are going to have the issue. I would do a compression test as a starting point and then hook up Forscan and check the O2 readings and fuel trims.
