Took 4 months but 1/2 that time was waiting for more $ to come in to finish up.
Again with mods, I had to go the unbeaten path to see what works and what doesn't. Fortunately for me, this worked out well with no kinks I can think of.
- Low Pinion Dana 44 from 2001 Dodge Ram shortened to use Wagoneer left & right inner shafts with stock Ram outer shafts.
The good
- Stock Ram Dual piston calipers 12" rotors
- Chrome moly inner axle shafts
- Low pinion chunk with great clearance to frame
- Sealed hubs, 4x4 on demand, no more regreasing bearings, nut torquing etc.
- Custom Radius arm design allowing me to unbolt passenger upper arm for 3 link radius arm or wristed arm setup for more articulation.
The Bad
- Sealed hubs, no more manual lockouts & driveshaft rotates full time (I don't care).
The ugly
- Another expensive mod that was not necessary.
I need to get it on the RTI ramp. This was as high as I could get it unsafely for now.
Track bar is stock TJ rear, Tie rod is '95 Ram, Drag link is '96 E150, all 1" diameter stock!
Ballistic Fabrication to the rescue!
What the 2001 Dodge RAM axle looked like when I got it home from the wreckers 71 1/4" WMS to WMS !!!!!!!!!!!!
After I shortened it cutting off inner "C's" and rewelding back on. Made block off plate since I'm not using CAD, I have one piece inner shaft!
Brackets on and ready to go
2" - 1/4" wall DOM Lower links
1 3/4" - 1/4" wall DOM upper links
Ballistic joints on frame end
Tranny and link mount
The good
The Bad
The ugly
