- January 27, 2002
- Texarkana AR/TX
- 94 SAS sport
-motor is 262 cubic inch Bowtie motor, from ASA racing origins
-oddfire crank
-Brodix aluminum heads
-single plane carb style intake converted for EFI, with PTE cast carb base to TB adapter
-large air-water IC, icewater is used for the runs, tank is in the bed
-mild hydraulic roller camshaft
-FAST computer for oddfire
Motor spins to ~7000rpm
-Kenne Bell headers
-Garrett 72 series turbo running 22 psi of boost
-the axels, transfer case, front shaft, rear end all stock, the tranny is a 400, aluminum rear shaft with only support pieces attached to the rear end to keep it from flexing too much
-17" drag radials all around (275 front, 315 rear)
-PEP front coil over suspension
-stock type leaf spring rear suspension with mods
1/4 mi - 9.89 sec @ 137 MPH
1/8 mi - 6.35 sec @ 112 MPH
1.54 sec 60'
22 PSI
here is the video
http://www.sy-ty.com/videos/Jesse/hoover_9sec.mpeg
-oddfire crank
-Kenne Bell headers
1.54 sec 60'
22 PSI
here is the video
