justinmoore38
- December 20, 2020
- Jacksonville, FL
- 2008 Explorer xlt 4.0l v6
I am ready to drive this thing off the pier into the Atlantic! First I replaced the throttle body assembly w/ tps. Worked for about 5 months then the same codes. I have replaced the tps an additional 2 times. I just put a new tps on yesterday and I'm still getting the A/B correlation tps code. The tps connector wires show no signs of damage. Also, the check charging system light comes on everyday. Alternator output @ 14 volts and battery tested @ 13.7 volts.
Any ideas? I'm thinking it has to be the PCM.
