You dont have to change carriers if you havent already bought gears. You can get a set of thick 4 series gears for the 3 series carrier.
4:56 isnt very low considering you're gonna run 37's. Do you have other plans or did i miss something?
you can interchange the 760x's with any 297 joint as far as I know, you dont need special shafts.
So they have the same cap size just a bigger body?
anyone got a EB passenger side inner axle shaft they want to part with ...
Leave that thing full width, you'll be happy you did.
You cant cut it down and run just one stock EB shaft. The stock EB shafts use the little 260 style ujoint instead of the bigger 297 the truck/big bronco uses.anyone got a EB passenger side inner axle shaft they want to part with ... feeling lazy today and dont want to look for one.
I got 2.5" jhonny joints with a cast on 1.25" shank for $35 from www.trail-gear.com It was about the cheapest I could find. Add the jam nut and weld in bung and it was around $53 each or so. I liked them better cause I dont have to weld a bolt on to them and risk warping the unit.
