Since the day I got my 2012 Explorer XLT, AWD with Tow package (Aug 29th, 2011)(2853 miles now) I have had a vibration that started off softly in the gas pedal between 1200-1500RPM. I have driven two other 2012 Explorers and they also had a slight vibration in the gas pedal between 1200-1500RPM.
- After several weeks of driving it has gotten worse to the point where it feels like I have an electric razor buzzing under my foot between 1200-1500RPM and 2500-3000RPM
- Completely smooth at 2000RPM.
- My transmission is also making a muffled whining noise when using the gas pedal at most speeds.
- When coasting no whining noise and no vibration in the gas pedal.
- Takes longer to notice first thing in the morning when its cold out.
I have already made a thread on this here
http://www.explorerforum.com/forums/showthread.php?t=332856&highlight=gas+pedal+vibration
However people have stopped posting on it.
I have been reading this thread and was interested in HiGrafiX issue.
- HiGrafiX did you notice your gas pedal vibrating along with your other issue?
You mention "accelerator".
I see in your comment "My problem was a loud whining noise sometimes accompanied by a vibration in the accelerator that occurred near the transmission shift points.
The part was a high pressure line for the transmission cooling system that vibrated and made a noise during transmission high pressure points. It is part of the towing package. "
So did your gas pedal stop vibrating (if it was) after getting the high pressure line replaced?
Does anyone else have the gas pedal vibration with or without the transmission whine?
If so was it fixed?
And how was it fixed?
I have been working with Cory and a Ford rep on this.
Also this is the replacement vehicle after my 2010 Explorer was swapped for it under Ohio Lemon Law because my 2010 Brakes kept failing and after 78 days cumulative in the shop and 6 months Ford could not figure it out.
(It ended up being air in the line like I told them since day one after the left front caliper failed and was replaced. Corporate Ford had the bleeding procedure wrong the whole time)
I was almost killed twice because of brake failure on the highway at a red light.
Please reply if you have any information that may on the off chance be helpful
Thank you everyone.
