EnergyFX
- February 8, 2020
- 2020 Explorer ST
Hello fellow Explorers. First post here, but have lurked for a few months until now.
In this thread I will detail fitting 325/35 R22 tires under an otherwise stock 2020 Explorer ST.
New vs. Stock Side-by-Side Comparison. The new skins are a full 2" wider than stock but only .3" taller diameter:
So, the wife and I recently purchased a 2020 ST and we have been loving it. However, I wasn't pleased with the factory tire sizing and overall look/stance of the truck. The factory tires just looked too narrow for a performance SUV and they were way too tucked into the wheel well. I spent weeks looking for any information on non-stock sizing and offset that would properly clear. There isn't much out there yet on this new truck, so.... I gathered what info I could, studied and measured the factory clearances, and ultimately took a bit of a risk and ordered some custom milled wheels and tires. In this thread I will attempt to share as much info as I can in case anyone else wants to take the same plunge I did, including what I would do differently knowing what I do now.
1st off, The Factory Setup:
2nd, My Aftermarket Setup (not recommended, read on for why):
3rd, What I Should Have Done (WISHD). If I were to do this over, I would go with the following (note: this setup is technically unproven as of this post, but is provided based on an actualized installation of the above "EnergyFX's" setup and my observations.):
With the "EnergyFX's" setup, there is about 1/3" clearance between the front tire and the front suspension (the front shock). This is .72" closer to the suspension than factory and is about as close as I would recommend getting to the shock. It is possible I may have a bit of rub under extreme cornering, but I won't know for sure until summer comes around and I can get a chance to try some aggressive driving and see the results. With the shorter sidewall I get from the 22s I do not anticipate this being a big issue. For now, it looks to be a good setup (reducing inside clearance by .72"). There is still quite a bit of inside clearance on the rear tires.
Factory Tire/Wheel Size vs. EnergyFX Tire/Wheel Size:
Factory Offset vs. EnergyFX Offset:
In hindsight, I believe a +35mm offset with 22x11 wheels would have probably been perfect, but would require a 315/35 R22 size tire. This would have also been an exact diameter match to factory. I plan to get to this size once I wear through the existing tires. I'll hve to send the wheels off to get the extra 5mm milled off the offset, but that's small price to get to perfect.
Factory Tire/Wheel Size vs. WISHD Tire/Wheel Size:
Factory Offset vs. WISHD Offset:
Rubbing/Interference: With the "EnergyFX's" setup, there appears to be a small amount of rubbing at hard-over steering. It is not severe and is probably not an issue, but is an annoyance nonetheless. This is another reason why I do not recommend the setup I went with and instead suggest the "WISHD" setup. From my observation there should be zero interference or rubbing with the "WISHD" setup, but that is yet to be officially confirmed.
Here is an IMGUR album that has all photos from this post plus a few more:
2020 Explorer ST Wheel Info and Aftermarket 22x11s
- Factory Wheel Size = 21x9 (WxD)
- Factory Wheel Hub Bore = 70.5mm
- Factory Wheel Offset = +37.5mm
- Factory Wheel Bolt Pattern = 5-114.3mm
- Factory Tire Size = 275/45 R21
- EnergyFX's New Wheel Size = 22x11 (WxD)
- EnergyFX's New Hub Bore = 70.5 (no change from factory)
- EnergyFX's New Wheel Offset = +30mm
- EnergyFX's New Wheel Bolt Pattern = 5-114.3mm (no change from factory)
- EnergyFX's New Tire Size = 325/35 R22
- WISHD Wheel Size = 22x11 (WxD)
- WISHD Hub Bore = 70.5 (no change from factory)
- WISHD Wheel Offset = +35mm
- WISHD Wheel Bolt Pattern = 5-114.3mm (no change from factory)
- WISHD Tire Size = 315/35 R22
