2000StreetRod
Moderator Emeritus
- May 26, 2009
- Greenville, SC
- 00 Sport FI, 03 Ltd V8
crankshaft oil passages
I found this response to a question posted January 10, 2006 on StangNet:
"The 4.0 crank is not suitable for offset grinding in power adder applications, this means we'd need a custom billet crank, high strength forged rods, and custom forged pistons. We'd shoot for 4.4-4.5L displacement with .060 over bore. The estimated cost of a stroker kit suitable for a power adder would be $3800-$3900 and would include the billet cranks, forged rods, and forged pistons. This crank/rod/piston kit would be capable of well over 500-600 horsepower but of course we really don't know what the upper limit of the block would be. with good preparation, good balancing, the block should tolerate similar power levels.
Tom Yentzer
www.supersixmotorsports.com
478-256-7766"
However, in Super Six Motorsports' 4.0L SOHC Tech Note dated 7 Nov 2005:
"The crank is neutrally balanced and actually looks pretty sturdy. It appears to be heavily counterweighted and is probably close to a 50% balance factor. The crank is robust enough to allow off-set grinding since it uses single pin rod journals, so the potential for stroker motors is there, based on the crank."
Since Tom Morana offers a 4.3L stroker kit using an offset ground OEM crankshaft he must have an alternative solution.
Is offset grinding the stock crank an option? I seem to vaguely recall reading, somewhere on here, that it wouldn't work because of the oiling passages in the crank or something like that. Anybody know?
Tom Yentzer
478-256-7766"
