- August 3, 2000
- NORTH IDAHO, 7B
- B2 "Slightly" Modified
- Callsign
- FOURTEN
12" of wheel travel
I cannot run a 2.5" shock, the shock will start to hit the axle shaft with this 2" kit, so we are going to run a 2.0, 10" travel threaded body and a 2.0 bypass on the front corners.
Drivers side is mocked up and tack welded, I am now working on the engine, valve train is going together, putting the 5.0 together and wiring it along the way. Updates are coming!!!! I have more time in the shop then I do in front of the pc (good thing!!)... but I will get progress posted
