4406 Questions | Ford Explorer Forums
4406 Questions
CobraMountaineer
Salisbury, MD
1998 Merc Mountaineer
Can someone give me the specs on a 4406 Transfer Case? I would like to know if it is full time or can I change it out to 2wd? Can I go to 4wd Low? Can someone help me out on this? Also what the hell is a brown wire Mod?
Spin:salute:
No, a 303E...i.e. a Cobra GT engine 5.0 Ecam. I also went underneath and I have a 4404-06 transfer case. Here is my VIN info
VIN 4M2ZU55P4WUJ00693
DECODED 1998 Mercury Mountaineer
Country UNITED STATES
Make Mercury
Vehicle Type Multipurpose Vehicle (MPV)
GVWR Class Class D: 5,001-6,000 lb
Model Mountaineer
Engine Type V8, 5.0L; OHV 12V; EFI
Check Digit 4
Model Year 1998
Assy. Plant Louisville, Kentucky Lt Truck
Production Seq. Number J00693
Brake System Hydraulic
Restraint System Air Bag
Body Type 4 Door Wagon
Trim Level Base
Drive Line Type AWD
Vehicle Class Mid-size MPV
Horsepower 215HP
Fuel Type Gasoline
Manufacturer Ford Motor Company
That is the stock info for it. I have the "302". just not the one that came with it ;)
a 303E is what I have in it. I just wanted to know if there was a difference in they way they changed it out (4404-4406) with a 5.0
Thanks man
Spin
your 4r70w transmission is still the same correct?
Then the 4406 2wd/4hi/4low t case will bolt in with some help
doesnt matter what engine you have in front of that trans
