Read more: http://www.4wheeloffroad.com/techar...super_88_axle_kit/photo_09.html#ixzz1rnKDYHOuThe shafts are 4340 chromoly with 31 splines and a large axle bearing found on 35-spline custom Dana 60 axles. The big bearing indexes into the new end flange and has more than twice the capacity of the stock roller bearing. The bearings and seals come pressed onto the axleshafts, so you don't need a press or a machine shop to help you.
The first pic I posted of installing the axle shafts is of the tube before I cut. It is the one with wheel bearing pulling tool waiting for me to thread up my slide hammer. As for as the shafts and if you need gears and other parts call Alex at PORC tell him Josh Jones sent you. I get most of my stuff from him. As far as the shop pressing the bearing they got the bearing which I could have done but they could not get the retainer so I going to use some heat and try and if that doesn't work I am calling Yukon and getting a new one. All the other shafts pressed on fine so I have no clue what the deal is.Stang, where'd you buy the 88 kit from? I'm in need of new axles and gears, etc... since I hit a patch of black ice the other day on the way to work and took out my rearend when it hit into a 8" curb. Link to more info and pictures...
http://www.explorerforum.com/forums/showthread.php?t=352607
Insurance is gonna cover it but I can get stronger axles then oem for cheaper then I wanna go that route. Plus they have the C clip eliminator and dual bolt pattern for when I do my SAS, bonus.
Was the shop able to get the other bearing pressed on? I had a question about the kit, you said you had to cut the end of the axle where the old seal and bearings go on? do you have a before picture? Sorry I'm not too familar with the 8.8's on these new vehicles, the last rearend I built up on a 4wd was on my old '79 Scout II back in the '90's. Any help, tips, info, pictures or links would be awesome. Thanks
I really like the rear bumper and tire carrier design too.
Thanks for pointing out the differences before and after before for the tube, I was up for 26 hours straight (work and 6month old son cutting teeth) so I had a brain fart. With the kit you still have use of the factory parking brake shoes and rotors? Or do you have to move upto F-150 hardware? Just google PORC and it'll show up or are they a site vendor? Again thanks for all the help, I just wanna get my rig back on the road and trail ready. Been driving around in my wife's '97 V8 AWD Mounty and it's killing me in gas.
Thought the D30 was working just fine. Why the change of heart?
Oh...what did the shop charge to press on those bearings? (might have missed it)
They were going to charge me 30 bucks(they didn't charge a thing since they couldn't get it done). Some NAPA stores have there own press might check them first. I just picked up a D60 for 200 bucks that is only reason I bought it. After doing research the 44 wasn't much of upgrade over the D30 so I figured I would wait til I found a 60. So this baby is going into storage until I get the rear I want to go with it. Probably won't be until Winter that I do anything with it. I am happy with the Merc the way it sits now. I might use it on something else or trade it too I just couldn't pass it up. LOLThought the D30 was working just fine. Why the change of heart?
YA WF88-31-KITThanks for the link. I'll give him a call on Monday. Is there a specific part # for the Ford 8.8 kit? Couldn't seem to find it on the site, tried to search under drivetrain/ axle kits then doing a site search for Ultimate 88 kit but no go. ???
I will build a new axle for the rear to match the front when and if I use the 60. Then I will have a couple nice axles for sale. With 60 and the Sterling 10.5 I will build I can run 42s without a problem. But I might just save the axle for the buggy I wanna build. That way I can keep the Merc my plush street/offroad rig. Already put 18k miles on it since the SAS. Love this rig is so cushy! And I get compliments almost daily now the weather is getting nicer.Are you still going to upgrade the 8.8 if you're sticking a D60 under the front? Or will you slowly build up the D60 and enjoy the Merc the way it is for now?
