- February 18, 2009
- Winnipeg, Manitoba
- 04 Mustang GT
As we are bumping performance on our Explorers, were dreaming of a knock sensor that would work with the stock pcm.
So, What about the 1996 F-150? It has a knock sensor, and I started wondering how close the PCM is. My guess is that its pretty close.
The knock sensor is located at the top, back of the F-150 5.0 blocks part number E3AZ-12A699A. If the hole isnt there, (As I think [MENTION=61294]vroomzoomboom[/MENTION] saw it isn't, so it would need to be tapped).
The knock sensor is on pin 6 of the pcm on the f-150's.
http://troubleshootmyvehicle.com/ford/4.9L-5.0L-5.8L/pcm-pin-out-table-1
It also looks like pin 6 of our 5.0 pcm's is unused.
It makes me wonder it could be as easy as just attaching the f-150 knock sensor to pin 6 on our current pcm's. I'm starting to think it is.
So, I guess the next one of us with our motors out will have to install a knock sensor in our blocks so we can try connecting it to pin 6 of our pcm's and see if it can be tuned.
