- June 16, 2003
- Humboldt, KS
- 2000 Mounty
Bug's bugs and more bugs--
Sheri went for a spin around the block last night and upon return Betty was dripping coolant. Seems we used the large water neck clamp at the smaller radiator neck and it started weeping. At least now I know where that clamp went--
Removing it required draining coolant. Went without a hitch. I then wanted to wsh her up so I went to the car wash which saw me coming because it broke right after I used the foamy brush. I stuckk all the remaining quarter in it out of desperation but no dice. So, I had to jet home and unroll my garden hose for a rinse. I was pissed so I hung note on the carwash ill changer telling the guy to fix his S&^t or go out of business, but either way quit coming down to empty quarters and split-/rant
ON to this AM. She squeaked at me. So, I thought it might be the cam sensor but after removing the serpentine I discovered it was the alternator brushes. Some fine sand paper fixed that, but whoa what's this? blood? kinda looks like blood but no, it's transmission fluid on the skid plate. hmmm. Looks like whoever ( yeah it was me) tightened the transmission fittings was getting hungry because I gave them another 1/4 turn and the leak stopped.
So, might as well get this flush out oil out of there-did that and dumped the entire oil filter contents onto the front skid plate.
Fast forward through a roll of paper towels and I finished up the oil change. Got it all back together and Sheri wants to take it out for an A&W burger and a root beer float.
I stuck the front drive shaft back in and still get a real fast vibration starting about 60 MPH which was not present without it. I did notice the front slip yoke slides out quite a bit. from where the front yoke attches to the front diff, the yoke "could " slide back bout 5-6 inches. Like it is near the end of the splines??not sure if this has anything to do with a vibration but the shaft sure could be longer. I do have a longer yoke from f150 I could use a conversion joint in-
Maybe I need to send it out for balancing?
